Assuming you have room for a double slot cooler, what you want is the Arctic Cooling NV Silencer 6 Rev. 2. It's dead silent and uses direct heat exhaust, so the hot air doesn't get recycled inside your case. It also has a giant conic 72mm fan that is optimized.
I'm currently using it on my 7600GT, works beautifully. Newegg stopped selling them, but there are alot of other sites that still sell them. They also pop up on ebay every now and then with low starting and ending bids.
