Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Does anyone own one of these cards? I am missing a capacitor and need too know the part number so I can see if i can replace it. There was a photo of the card on gamers depot but I can't tell from that.
The lifetime warranty is only if you have the receipt. Which I don't, I got it off ebay awhile ago. The warranty wouldn't cover that capacitor being sheared off either even if I did. Checked into all that already.
With BFGs history of support, at the very least they're likely to point you in the right direction. At the worst, they tell you that you have to deal with it on your own. Call them and find out if they can help; it's not like a phone call's going to cost you anything.
