BF3 SLI Problems - Flickering Terrain Elements
code137
For a while I was getting flickering terrain elements using SLI. Using either card independently resulted in no flickering but the second SLI was enabled bushes and other elements of the landscape would begin flickering. I though I had solved the issue when I switched back to the WHQL drivers instead of the most recent 290 beta drivers. Now after the recent patch even the old WHQL drivers are showing flickering elements everywhere.
Anyone else noticing these issues? I made a quick video to show what was going on http://www.youtube.com/watch?v=9ETSuG1Fiko
That's with v-sync disabled. With v-sync enabled the black portion of the flicker seems to get reduced so it seems a bit better but still flickers wildly. I did notice that if I somehow modify a terrain element in some way, like exploding a grenade on a small portion, that the surrounding elements will stop flickering. However everything in the distance would continue.
GTX 260 SLI here. I've seen the problem you described, but I honestly don't know what I did to solve it. Did you try rebooting?
Yeah I've tried rebooting, tried alt tabbing, tried 3 different driver versions, and even tried reinstalling.
I was getting that now and then, it's some sort of SLI bug.
Try reseating the SLI bridge or swapping it if you got a spare.
I also noticed this problem in 3D Mark 11 Combined Test (at the end) where the flags would be all flickering.
It's been bugging me for months, that physically swapping between two different SLI bridges every few months stops it from happening.
If I were to RMA the cards seperate, they wouldn't find a fault.
I have tried swapping bridges but that didn't seem to have any effect for me. I'm really hoping it's just a driver issue and not anything hardware related. I'm guessing its more software/driver considering others seem to experience the exact same problems.
The other possibility could be it's having trouble when set to Ultra textures, not enough VRAM.
I'm betting it mainly happens on 64 player servers.
I'm running MSI GTX 580 Lightning Xtreme cards with 3gb of vram each. The most I've seen the game use is just a bit over 2gb and without MSAA on I normally max out at around 1800mb, so I can't imagine its a vram issue. Just to check though the flickering continued with textures set to high and with my resolution lowered to 1920x1080. The strange part is what I mentioned in the first post where it will actually stop flickering within a certain distance when something like a grenade goes off. So if i walk up and drop a grenade on a hill that has flashing bushes that hill will stop flickering but the rest of the bushes and the ones in the distance will continue.
GTX480 sli here, 1080p.
I get mad flicker when nobody is in game, but it dies down when the servers fill up. And it only seems to be the foliage on the ground in certain maps like metro rush or damavand conquest where it happens.
vram usage ~1400mb (ultra textures, 2xmsaa, high fxaa)
Yeah I noticed that it only occurs on certain maps. I really hope they can find a fix for it though because it is amazingly distracting. The fact that it seemed to have been fixed for me before the patch using the older WHQL drivers has me hoping that they will work something out.
Damn, I am having the same problem. I hadn't tried the newest drivers and was hoping that might fix it, but I guess not. :( This is really frustrating, as I JUST got my 2nd card for SLI and was really looking forward to the performance boost in BF3. If anyone has managed to fix this issue, please let us know! I hope it gets addressed in a driver update, although the fact that it is still happening with the latest beta drivers doesn't have me too hopeful. :(
Same here. GTX570SLI and I get flickering foliage on occasion. It always just goes away on it's own though. Does'nt happen too often. Still on 285.62 drivers though. Have'nt tried with 290.63.
I don't think this is limited to SLI. I have a single GTX470 and this is really bad at times in Caspian. Alot of clipping and "seeing through" the terrain. Happens in the 290 and 285 drivers. Don't really know or think this is a driver issue as this was happening in the beta along with flying tanks. :p
Only 1400? I wonder if sli reduces the VRAM requirements. At those settings, my single 480 would max out the vram at times.
I get this sometimes. It usually goes away after a few minutes. It's happened maybe 5 times since BF3 launch for me on SLI 580's.
