BF3 + Joystick + n52te SOLVED
arcsum68
Finally got my Logitech Freedom flight stick working in BF3, so I thought I would share.
First off, deleting all the bindings did not work for me, the game would not recognized any movements in game but Windows was fine.
My problem was that that I have 2 devices, the Belkin n52te and the Logitech Freedom. I read somewhere that BF3 will only recognize one gaming device. Digging around in control panel>hardware and sound>devices and printers I discovered that I had 2 installed game controllers. One was listed as the Logitech and the other was a generic virtual device, the properties revealed it to be the Belkin. Since BF3 will only recognize one, and my Belkin worked fine then that would obviously mean the flight stick would not work. I tried setting the Logitech as the default device, but that still didn't work. Here's the tricky part, the Belkin is also listed as a separate keyboard in Devices.
Next I went into device manager and expanded the Human Interface Devices, then disabled the 2 Virtual Hid Devices that the Belkin controller had created. I assume it does this for the D pad, but I only use single key functions for everything so I was perfectly fine with not having that functionality and it made no difference to anything I use the device for.
Once in game, I could remap the keys just like you would expect. (it calls things by odd names, IE the Trigger was not called Trigger)
FWIW, I do not think this problem exists if you own the slightly different re branded Razer Nostromo version of the n52te,
Hopefully this will help someone else get their joystick working. The game still needs to allow for adjustment settings, but at least I can get around in a plane. I prefer the mouse/keyboard for the choppers so I did not play around there at all, but would assume it to work just as well.
Sadly, it does. The way I got my joystick to work was using Joytokey, a keyboard and mouse emulator for joysticks.
Bummer, you might want to try my method.
Joytokey was a PITA, and on the occasion that my joystick did not self center correctly or if I left my throttle on it messed things up for me.
Really wasnt a solution for me.
I personally use a PS3 controller via Motionjoy. It isn't a joystick in the flight stick sense but it's better than the keyboard. Motionjoy is a bit buggy with bluetooth. Controller will ocassionally revert to non-xinput mode when using bluetooth but for the most part it works. Good for flying the jet on the fly but heli not so much.
Well, I am sorry for reviving an older post, but since there are still many players having issues with a flight stick I thought I would add to it. I made a post and was directed to this post by an [H] member. My post and questions: http://hardforum.com/showthread.php?t=1665977
I will try what the OP of this post posted.
Well thats unfortunate for me.I have 3 game controllers that are recognized... My razor nostromo, saitek combat rudder pedals and my Saitek AV8R-2. So basically if I want to fly with my joystick I would have to sacrifice my Razer nostromo (which is not going to happen) and pedals just to get the thing to work? :confused:
Yeah, and they still haven't fixed their horribly poor excuse for PC controller support. I can't use both a joystick+throttle and rudder pedals because of this silly bug.
I had to exact same thing you did with my setup. My other device was the G13 joystick.
So I guess there is really no alternative solution to this. thats bull... Dice sucks
