BF2 Settings with SLI 7800GTX
petersondm
Hey all just installed and ran my new BFG 7800GTX in SLI on a AMD 55FX system. I was running BFG 6800 GT OC SLI before that and getting 50+ FPS with some settings set to Medium and 4X AA+AF. Now I read some people setting everything to high and getting 50+ FPS in BF2 but I am only getting 20+ FPS.
What is the best setup for visual quality and performance using this setup:
SLI BFG 7800GTX
AMD FX 55
ASUS A8N SLI Deluxe
2 Gig 3200 400 DDR nothing speacial.
PS PC Power & Cooling Turbo-Cool 510 Express / SLI Product
Audigy 2 ZS
Good Point here is Resolution 1920 x 1600 on a Dell 2405 LCD and using 77.72 Drivers. The only thing I changed are the video cards and turning on all the eye candy in the game on the card.
Also I was somewhat confused by the NVidia Video Options. They are a bit brief in the explanation of what settings do what. The Mulit GPU one, no idea what it should be on.
Thanks
It might be wise to post what resolution you are running at...
Secondly if people are getting 50fps and you are getting 20fps this still MEANS NOTHING unless you are running the same resolution.
Also, which drivers are you using?
Do NOT set global settings to some random AFR, SFR, AFR2 or something from the driver panel. Just make sure that you enable SLI and keep global settings at default and the drivers will pick up the premade BF2 profile for SLI.
1920x1600? Are you sure it isn't 1920x1200?
Either way it's a pretty large resolution. BF2 tends to suck everything it can out of your graphics hardware and then some. At that resolution, depending on your settings, you could have some framerate issues...
