BF2 Problem
UnMinded
Ok heres the problem i can start up and load into the servers fine. The problem starts after i hit the "Joing Game" tab i get in and my mouse wont move at all. My Game isn't frozen because you can still here all the noises and see the air plane or chopper fly around in the backround and see the body count tickers count down. So whats the problem? Is it just my mouse locking up? Thanks in advance.
I think it might be, what mouse do you have? I have seen people having probelms with their keyboards, I would try searching the web for some newewr mouse drivers/
Its not a speical mouse by any means.. Just a regular wire/ball mouse. Been playing on it for a couple of months and just started haveing the problem today..
I had this exact problem when I adjusted the mouse settings during a running game, which was a known bug. Maybe try restarting the game and making your mouse adjustments before you enter a game. This worked for me.
UnMinded,
Here's my guess - your default settings for your controls went haywire. When you get into BF2, go to "Options" and "Controls." Once there, you'll probably find that everything is blank. Just hit the "reset to defaults" button - or whatever it says - and it will load the defaults. Then, change whatever you had changed before (i.e. flight controls if using a joystick, PTT, etc.) and you should be fine. I've seen this happen once or twice before. Good luck.
I had this happen, I just reinstalled windows since it was about time anyhow ;)
