bf2 control response
bladeiai
since I patched I've noticed that I have problems with responce from controls sometimes(like a key is being held down after I have already let go of it or when I move the mouse nothing will happen. but it only happens everyonce in a while and its not lag(does it in single player) and the fps dont drop so its not like a performance problem. its very annoying tho does anyone have any idea what could cause something like this? at first I thought my mouse was f'ed up but my keyboard does the same sometimes any ideas?
Do you have wireless kb/mouse? If so, could be batteries. But most likely, the sight line between the kb/mouse and the base.
I dont think that it is related to the patch at all. I would do a spyware and virus scan on your system to make sure that you dont have any.
That's my problem. :cool: Except, mine lags a bit before moving XD I'm pretty sure it's due to my RAM amount, though. XP
If you do not have 1GB of RAM, you need to set everything on LOW and then expect some hitching.
If you have less then 1.5MB, you may have to use lots of MED in the settings.
Soulds like paging. Check to see if your hard disk lights when this happens.
Are you kidding me? I have 1GB of ram, and I run everything on high, with 4XAA and high filtering, and I have textures set to medium. I experience no hitching what soever, and no lag at all.
Ok, so you may have to run 'some' settings on Medium.
I have 1.5 gig ram and I dont think it is paging as I have a ram meter on my second screen and its not filled up, I will check for hard drive activity tho, but if ram were the case wouldnt there be studering in the game, my problem has nothing to do with studering, the game runs smooth as butter I just lose control for a split second
The only time I've ever had those symptoms was in a very laggy server, and in a single player game of my own against bots. Actually the server might not have been super laggy, but I was experimenting with running Xfire voice in game and it didn't work real well on this server we were on, causing the delays in mouse control.
its not because of the ram(altho it gets damn close, uses 1400 out of 1500) but there is no hard drive activity, it almost seems like a optical tracking problem with the mouse(like on a bad surface) but I know thats not it because sometimes the mouse buttons dont respond either, maybe I'll try a different mouse (I dont think that could be it tho, as I dont have this issue in any other games)
its really hardly noticable, except when you have someone in your sights and you try to take a shot and nothing happens
