Bezel Question.
I accidently broke the eject button off of my Sony DVDRW bezel while attempting to spray paint it. Ill try to glue it back on or rig something up but if that fails I'll obviously need to replace it. Is there any website that sells black universal bezel kits or something along those lines?
you should stealth it, that requires you to make a button, which works soooo goood!
