Bezel Compensation woes
rgraze911
I set up my 5850 in eyefinity w/ bezel compenstion. The bezel compensation works fine in windows but when I start BF Bad Company or guild wars there is no compensation. I also tried searching for this problem but havent found anything relevant.
did you choose the resolution for the compensation in game?
In order for the compensation to work properly, you need to choose the higher resolution in the game's video options.
Please read this: "One interesting thing worth noting is that you WILL have to change your in-game resolution if you are playing fullscreen in order to benefit from Bezel Compensation. The standard ATI Eyefinity size for our three 24" displays is 5760x1200. However, in order to benefit from Bezel Compensation we have to increase this (proportional to the aspect ratio) up to 6036x1200. We can of course use a lower resolution as well, but we won’t be rendering at the native Eyefinity resolution with Bezel Compensation. "
From here: http://www.hardocp.com/article/2010/02/17/amds_ati_catalyst_102_103_preview/2
Thanks for the info that was it. I also see people talkin about how they run the game in dx9,10,11. There's a way to change the what DX is used?
Have to set the DX version in the initialization file in your BC2 folder. Filename is "settings.ini" and entry is "DxVersion=x", where x is 9,10, 11 or auto.
