Bezel Compensation in Non-Eyefinity Mode
Oldie
Mean Old Administrator
I have a 3x1 setup and would like to have bezel compensation enabled even when the displays are acting independently. Does anyone know a way to do this?
Basically. I also think it's not needed either as I consider each monitor a separate work station.
I'm actually asking so I can avoid photoshopping a wallpaper to give it a more "seamless" appearance. It looks great w/bezel compensation but doesn't line up correctly without it. I can fix it, it's just a PITB.
Ocean that seems to have the functionality I'm looking for but it's not aligning the wallpaper correctly. May be a win8 issue or I might need to play with it a bit. Either way, thanks!
ive concluded that the program only works really well with huge images. if you want native resolution wallpapers, its almost impossible with this program, horrible program.
basically it doesnt give you the option of defining where a background border will show up if using a native res wallpaper thats cropped in the middle, or not auto matching a zoom (out) with a crop for large images.
only use for the program seems to be if you are using giant source images, and it will be an unlikely native resolution. :(
Eh, I was starting with an 8000x8000 image so source size wasn't an issue. :) I tried editing the json files to get it to align properly and couldn't get it to play nice (may be a windows 8 issue) so I just spent the 30 minutes in photoshop to make it look right. :p
If anyone wants a properly aligned wallpaper for a 5760x1200 setup, here it be:
http://www.newoldie.com/forumpics/earthpaper3.jpg
