My main watercooled pc died about a week ago, after I finally dissassembled it I found what had caused the motherboard to fry so soon.
There are a couple capacitors really close to the retention frame. Because of the amount of force the springs were supplying the pins managed to poke through the sticky black insulator on the backing plate and make contact with the metal underneath.
The holes.
Here are the caps that caused this.
The solution? Well once my RMA comes in I'm going to use a pair of nail clippers and chop off the ends of the pins. Easy fix if youre observant enough to see it before your board fries.
The holes.
