This is another really good point. Make sure your sound options are set low w/ no EAX. I don't remember what sound options UT had so play w/ them. Also makre sure you're playing at 640x480. Turning down all the options but trying to run at 800x600 or 1024x768 will tax the fill rate and memory of the Voodoo.Originally posted by Jondbold
if your running it with eax turn it off unreal blows goats with eax performance you'll see another 5-10fps hopefully.
oh, not at all...a winxp installation that is stripped down can decend to the ~1GB range, and a standard installation doesn't usually climb above 2. That leaves plenty of room for (older) games.Originally posted by bobsaget
doesn't winxp take up like 3.5GB itself? How can you have games and WinXP Pro on a 4gb hard drive?
