better oc'ing with watercooling?
frankyk
if i had watercooling, could i push the overclock even further? or is most overclocking just limited due to hardware?
like i heard in another post some hardware doesn't oc well ? this is specifically the x1800xt
Sometimes you can get a bit higher/more stable oc on water than air, sometimes you can't.. Water will let you crank the volts up a bit more and still get rid of the heat, often giving you a bit more oc room.. But, sometimes a chip will go "this far and no further" no matter how many volts you push through it or what cooling solution you have..
The X1800XT is a very hot core. Since you can up the volts in software, and it runs so hot in the first place, it's a great candidate for watercooling.
Yes, watercooling will make a difference. In my own experience, I was able to overclock my old 9800 Non-Pro flashed to Pro far more than with an air-cooling solution. Watercooling my current 6800 GT showed a similar trend--watercooling got me further in my overclock. My GT, which I purchashed back in July of 2004, has been overclocked and water-cooled since the day I purchased it and it has been stably running at 420mhz core (from 350mhz) and 1100mhz (from 1000mhz).
oh, so the limits of overclocking isn't based on heat, but just hardware? even if you had the best cooling (liquid nitrogen?), hardware can only be pushed so far?
It is not just based on hardware. There are many factors.
