Better machine....lower 3dmark05 score
I know I've seen posts about this before, and I can tell that game performance kicks ass with my new setup (compared to my old setup at least...probably sucks compared to some of you guys with money coming out the ears so you have 2 7800GTX's and the fastest dual core cpu :p).
Anyway, went from Athlon XP 2500+ Barton, 512MB kingston value select ram, a foxconn motherboard and my unlocked 6800LE (12x1, 6vp 375/850)
to
ASRock 939 dual sata-2, Athlon 64 3200+, 1gig dual channel corsiar xms and my 6800LE unlocked, etc.
But my 3dmark score dropped by about 200 points. :confused:
I haven't really tweaked anything in bios except for changing the ram timings to 2-2-2-10 (i read in a review of this ram that 10 was better than 5 for a64 systems stability)
Anyone know what settings I should try tweaking? Anyway to check whether that 1000Mhz FSB is actually doing it's job?
is that an agp card?
if so try the uli reference drivers (downloadable from uli taiwan site)
to
Get CPU-Z from www.cpuid.com to check the FSB, u would think the 3200+ would help u get about 500 more than u did.
Yeah, AGP.
What drivers would that be for? I installed ULI's all in one thing to install the agp driver.
Is that what you mean? Or video card drivers (instead of Nvidia's drivers)?
You need to be sure of the following...
Ram is at a 1:1 ratio
Bios option set to DDR200
make sure ram is at 1T
if overclocking
put cpu to pci-x to async
turn off the syncronise one
HTT is set to 800 or 600, preferably 800 on both noth and south bridge
make sure you are using bios 1.20
agp needs to be at 64 for high overclocking
I set the ram to 200 and 1t before I posted initially.
Don't know how to set/check if it's 1:1 but going by this pic I'm guessing no?
http://img506.imageshack.us/img506/364/ram3xj.jpg
(That was taken before I made changes though. It now says:
Frequency 200Mhz
FSB/DRAM CPU/10
2 clocks
2 clocks
2 clocks
10 clocks
11 clocks
16 clocks
I tried some of the other changes you mentioned, but could only find the cpu to pci-e thing, wasn't sure what you meant about the "synchronize one" and I set the htt on nb thing to 800.
I got some weird problems though. I took a screenshot, and when I went to paste it into Paint, my computer rebooted....3 times in a row after changing some of those settings back to default. :(
Not sure what's going on here.
Seems my "paste in Paint reboot problem" was related to some change I made in the BIOS since I just loaded the "optimum defaults" and did another copy and paste which worked fine.
How frickin' weird is that?!
3dmark is all about the graphics card. I am going to be buying the same motherboard and I have checked it out thoroughly. It is the one with agp and pci express right so you can upgrade when time comes around. Well the agp slot set up is not perfect. You will get like a loss of a few fps. I think in the reference boards the pci express was a big difference and the agp was almost the same compared to a comperable MB. This ASRock version really increased the pci express speed and lowered the agp slot scores a bit.
Well even if your motherboard is not the one I am thinking about the first sentence is still true. 3dmark is all about your vid card and by extension your motherboards agp implementation. So your new computer might not be set up right as far as some bios setting or driver. Or the agp slot performance is just not as good as your old mb.
Check:
Install Latest BIOS
Install Lastest Chipset/IDE/Audio/SATA Drivers
all POST SP2 patches
latest video card drivers.
just my 2 cents
temporalwar said:
Install Latest BIOS
Don't do this. Later BIOS versions for this board are crippled in regards to overclocking. The good ones are the official 1.2 and the ocworkbench betas 1 and 2. The later versions 1.3, 1.4 even go so far as to render a vcore mod useless. I don't know if it can be recovered by rolling back to a prior version either. Even if you don't OC, I have yet to see a reason to switch to one of these later bioses. The other ideas on the list are good though.
I'd say your 3dmark score is about right for this board. Mine went down as well when i switched from my 2.4A+PT880 to my Opteron 146 and this board. A similar drop of ~5% in score. The P4 couldn't touch this system in actual game performance though.
I don't know much about improving 3dmark scores, but maybe playing with AGP Aperture size would help.
2005 is a videocard benchmark, period
your old system was maxing out your videocard in 3dMark2005, so even if you had a 5Ghz Athlon FX, your system would still score a similar 3dMark2005. + - about 200 pts
Try 3dMark 2001 & 2003, your scores should be much higher.
1: uninstall your video card driver. Use a driver cleaner.
2: reboot
3: install the agp driver for the mobo
4: reboot
5: install your video card driver
