better hs/fan?
Or the Zalman 7000....little smaller if the 7700 doesn't fit your board. :cool:
From the Newegg description of the Swifttech heatsink:
The MCX6400-V is compatible with 80 fans
Does this mean that there are exactly 80 fans compatible with it, or that it supports 80 fans at once? :rolleyes:
weezle69 said:
I have an a64 3500 with a abit an8 mobo. when i play games the temp goes to 73c and it idles at about 50c so im guesing i need a new hs/fan. what should my temps be (how hot can it get without frying?) and i was lookin at this http://www.newegg.com/app/ViewProductDesc.asp?description=35-118-114&depa=1 . any other sugesstions?
The A64 enters dangerous territory around 100c, operational spec is around 90c. Your temps are too high, these are cool running chips. You do not need a new cooler, you need to fix whatever is installed wrong.
Take off your heatsink, clean both surfaces with rubbing alcohol to remove any thermal grease or pads, and apply a THIN Coat of arctic silver to the CPU, then reapply the sink. Also, what is your case ambient temperature like? You want at least 1 80mm fan blowing in in and out in addition to the power supply fan. Ideally 120mms.
Note, the A64 shoud not fry it gets too hot; it would certainly appear they have an internal thermal fail-safe feature. Mine shuts off when it hits around 100c.
No, the Athlon XP (K7) was specced for 90-95C depending on the core, the Athlon 64 (K8) is specced for high 60's to mid 70's depending on your core. 100C is WELL over spec for an A64.
DisrupTer911 said:
I'd recommend the
Swiftech MCX-6400-v-
and a nice quality fan.
you've got plenty of choices b/c the Swiffies are designed to work with even low cfm fans and cool superbly.
I love mine. It came with an 80mm low-noise Delta fan, and it does a great job.
You need a fan for those thermalrights as well dont you? And if so what would you guys suggest?
