Better drivers for x850pro?
Status
Not open for further replies.
Cold Dark Shadow
Just got the card and installed it and used the drivers that were on the install disk and was curious if theres better ones for it out there? Im not having any problems with the ones i just install or anything, like i said was just curious if there better ones to use :)
Also i heard some of the x850pros can be OCed to XT specs?
EDIT:
Just noticed now when i brign up a new smaller window i get these little colored like dot things, like in groups of 3 side by side, when i drag the window, they pop up where the window was
When i tried to play Q4 the words on the menu were streaky and jumpy
Status
