ne0-reloaded
- Jul 1, 2003
im not very happy with the temp of cpu and system. before i used to have temps of 32C and 44C at max. Now im having 50C on idle and God knows what on max. i currently have 6 fans (all 80mm), not including the hsf. i have 2 as intake, 2 as exhaust, one blowhole blowing out, and one side panel blowing in. I replaced my stock hsf for a thermalright slk-700 w/ tmd fan (36cfm); i believe the hsf is 54mm. also im using artic silver 3. basically i wanna know what i can do to make the system cooler other than going with a water cooling solution. i have room for 2 more intake fans at the bottom front of the case. the pc is already loud as hell, but ill put up with it if i have to. my room is already hot as hell, so i know that's probably attributing to the heat issue. im thinking about getting a different heat sink and/or fan, a 80mm one or getting some AS5. if anyone have any hints or suggestions please post.
thanks.
also my wiring job was pretty cluttered, and i thought that might be the prob, so i bout split loom, ties, and put some rounded ide cables in. it didnt help any, but it looks a little nicer. im not sure if installing a fan controller would work, but if yall think so give me the link to one so i can check it out.
thanks.
