BETA DRIVERS: 4870
oozish
Where can I find these; I thought there was a 8.7 out.... Sheesh, I've been googling for 10 minutes and still can't find anything past 8.6 or hot fix...I sux.
Really? You should really work on your Googling skill then. :D
A search for "ati beta driver" gives the above stated link as the first result.
yeah, thats how I found it. It was the first link that popped up. Practice your "google-fu" young grasshopper ;)
Really I'm not that bad, heh. I had some other word in my search that must have screwed it up because that didn't come up for me. I think I had 4870 in there. 4870 beta driver, ya, that one.
Is this the driver you would recommend for use with 32 VISTA?
I'll use 8.6 if you think it's more stable, I like stability most.
THanks,
