Beta Bios question
Jeeprs69
I have a ASUS A8V and it's running the 0219 version. Can't find that on the Asus Website?
But they have a Beta Bios 0221. What is the difference between a beta version and a regular?
Should I try the beta? I'm not a computer wiz by any means.
its a bios thats been released but may not be the final version.generally nothing wrong with using them.i use them all the time,but if im running one and the final version comes out i usually put the final version on.most of the time there is no difference between the beta and the final.it just gives asus a little more time to add some small additions if needed.in all my years of flashing boards bios'es ive never had a problem with a beta version especially asus.give it a try and if your happy with it run it untill the final comes out or the next bios comes out and then flash it .
of course if your not having any problems with your board,leave it be.dont flash just because there is a newer bios out.it may be the newer bios just has newer cpu recognition built in.rule of thumb with bios,dont flash if your not experiencing problems.if ther is a reason like a newer cpu going in thats fine or if the newer bios has a fix for an issue with the board your experiencing then by all means flash.some times flashing will not run the same as your older version,or wont o/clock as high,and bios flashes can go bad too.so just dont flash just to do something new,only flash if there is a reason to do it............................
There's an old saying, if it aint broke, don't fix it. Now theres also a saying "Do as I say, not as I do". I always update my bios to the latest, try betas, etc. There's always a possibilty that you could lose power in the middle of a bios update and hose your computer, who knows. But unless the beta bios adds some functionality you need, why mess with it?
I was just curious, mostly. Gotta learn somehow :D Would it add stuff like a option to adjust the vcore ? I haven't found out how to do it yet. It has a Overclock feature- 5%,10% and
etc. Also has a manual setting and when I tried that with 215mhz something or other :rolleyes: it put my vcore at 1.66 volts :eek: so needless to say my temps went up. So right now I'm back at stock till I figure out more what I'm doing. So I'm going to ask more questions down the road
