I have an HP Pavilion DV9000t notebook. It has a numpad, so there is no need for a keyboard that has mixed both numbers and letters, controlled via numlock.
I'm going to paste this from another forum in which someone else was having the EXACT same problem, but with no fixed result.
On the main keyboard the keys 'mjkluio' produce '0123456' (respectively) when the numlock is on and the numeric keypad also (as expected) produces numbers.
This is not supposed to happen on the main keyboard; those keys should produce the characters 'mjkluio' regardless of the numlock status.
When the numlock is off the main keyboard keys are correct, but the numeric keypad has the other cursor movement values (as it should).
However, what is supposed to happen when the numlock is on is that the numeric keypad produces numbers and the main keyboard does NOT produce numbers with the keys 'mjkluio'.
I'll tell you what I've tried already. I replaced the notebook keyboard. I also checked the values in the registry and set them to Numlock ON when Windows starts; this works fine, IF I keep the Numlock on. The moment I turn Numlock off and then back on again, this behavior continues.
Can anyone help??? Thanks!
