BestLinkNetware (cheap Cat5 & Cat6 patch)
Good deal, if I didn't have a spool of cat6 in my garage and a good crimper, I would be all over this. "100Ft Cat.6 Shielded / $8" = FTW
unless this is for some corporate or work related task, when you find yourself needing 100ft ethernet cables, it's time to start considering wireless....
Give me wired any day of the week, totally worth it in the long run.
Wireless != cat6.
No 1080p streaming over wireless. No LAN parties with wireless. I'll be running a cat6 from my routers to my kitchen pretty soon for streaming.
Wireless != cat6.
And when you do that, are you going to buy a 100 foot patch cable, or a bunch of wire and put the ends on yourself?
100ft cat 6 isn't that expensive from Monoprice. I've considered crimping myself, but I had a hard time getting one to work when I tried it and now I've got most of the wires I need, so a 1000ft spool isn't the best way to go.
Besides, I need to run 2 more dedicated power lines to my basement. I'll run the cat6 at the same time.
making cable your self isnt hard at all.
In a pinch, I would rather cut open a bag and have a working cable in seconds. I don't like to make cables unless I have to. I don't mind making them...
i've had no problems with 1080p over wireless n.
True but don't most people stream over 360 or PS3? Definitely nice to have a cable for that. (no N for 360 or ps3)
And you ain't doing gigabit transfers without cat6
I should have underscored my point.. which was that it was a 100ft shielded Cat6.. The only reason I have a spool in my garage is because I just wired my entire house with it, and have a lot left over. I agree it's a lot nicer to have the cables with the ends, and I have never seen precrimped cables this cheap.
I've seen HD streaming over N wireless before, but I wouldn't want to depend on it.. there's a certain satisfaction knowing you dont have to troubleshoot a wireless stream problem if a stream problem occurs.
Too bad this company charges $70+ to ship a $8 cable here to Canada.
Monoprice has better deals on their shipping ($12 to $25) to Canada.
