Best Wireless Adapter
I went ahead and grabbed this with an Intel 6300 for $32 total. I'll let you guys know how it performs.
Looks good ;)
Be careful with Intel cards on ebay though, since I have read there are fakes on there.
I put together the card on Sunday and I am impressed with the performance. The only issue I had with the cheap mini pci-e adapter was it did not have the hardware to screw the card in place. I used a zip tie to hold it down.
I am fairly close to my router so the small antennas that come with the adapter work fine. If you need better antennas, you could try something similar to this.
