Best Window Kits
choogi
I want to cut a side window into my Lian Li a05b but haven't ever done it before. I was just wondering what some of you guys might recommend for window kits =)
Drill with 1/8 inch bit.
Dremmel or other cutting tool.
Rivet gun and box of rivets.
Sheet of Lexan/Plexiglass.
Creativity.
Profit.
EDIT: For clarity, you get a sheet of plexi/lexan that is larger than the window you want, you cut the window and lay the plexi/lexan on the back side (inside) of the panel and clamp it down. (Keep it tight, alignment is important)
Then, drill a hole every 2-4 inches along the outside of the window hole at least 1 cm from the edge of the window. Be sure that your drill goes through the panel, then through the window plexi/lexan.
Then, remove the protective cover from the plastic window, re-align, and rivet to your panel. You are done.
Clean up the edges of the window cut before attaching the plastic.
