Best widescreen LCD under $300 for gaming?
Wildfire788
I've been shopping around and still haven't been able to decide on a monitor. I've been looking at a few on newegg:
Viewsonic VX1940w - http://www.newegg.com/Product/Product.aspx?Item=N82E16824116095
Asus V222U - http://www.newegg.com/Product/Product.aspx?Item=N82E16824236028
There was a 20" LG that looked promising but has apparently been deactivated on newegg. I've also heard good things about Samsung but they have so many 20"-22" lcd's and I have no idea which of them would be the best choice.
I'm just looking for a widescreen lcd that will last a while, look good with first person shooters and under $300. Any suggestions would be appreciated!
I'm in the same boat mate but I'm leaning toward a high end CRT from a local specialized shop. I know that LG and Samsung both have new models coming really soon. ...might be worth waiting..
I ended up buying the Samsung 2232bw and am very impressed by the monitor.
Excellent picture right out of the box, no dead pixels, minimal backlight bleeding, no noticable ghosting whatsoever in CoD4 or Counter-Strike: Source, and I can switch between DVI (pc) and VGA (xbox 360) with one button press.
Very happy with it. Hopefully it lasts a long time!
www.bestbuy.com
I bought this one in store for about $270.
I have absolutely no complaints about it with one exception. That is that it came with a VGA cable rather than a DVI so i had to buy one.
Looks great, text is clear and very readable, good for gaming etc.
I'd get the Soyo 24" from Officemax for $279. Great for gaming and hey...it's 24"
dumb buy with the 2253bw coming out in a week or to.
Dude, the only difference is a higher claimed contrast ratio.
Samsung has released other new 22" monitors since the 226bw as well, and they aren't as good. I've already seen on a Chinese review site that the 2253bw has a good amount of backlight bleed.
Not to mention, new monitors are often plagued with problems at first. The 226bw is a mature, proven monitor.
the actual contrast ratio is higher to. 226bw is only 700:1, 2232bw and 2253BW are 1000:1.
Err... I know. I didn't say only the dynamic was higher. You missed my point though. Numbers on a spec sheet don't mean it's better, nor does the fact that it's newer. You should always base your decision on real reviews, not on what the spec sheet says.
Can I get any of those links, please?
