Best way to remove memory heatsink?
IceWindus
Well, finally sick and tired of my huge ass towers i've had these past few years, i've ordered a SB75G2 shuttle case and im gonna transfer my hardware to that hopefully by friday. One problem is that Hercules 9800pro has big memory heatsinks and those will have to come off due to the space between it and the Audigy 2.
What have you guys found that will work best to get these things off as safe as possible without damaging the chips?
There expoxied on, and i've heard a variety of different ways to take heatsinks off. From freezing the card, to using razor wire, to prying it off to letting it heat up and then taking the heatsinks off.
Hercules, with those huge ramsinks... damn, you may be out of luck. doesn't a single ramsink span two RAM chips on those cards? if that is the case, you can't twist them off, like you would normally do (you know, freeze it first, then twist it off to break the epoxy bond).
you might as well sell that card and get an identical one - BBA - without ramsinks.
I tried the freezing method on my 9800pro, and ripped 3 ram chips off. I tried pulling gently, twisting, and sliding. Twisting seemed to work the best though. If I were you, I would sell the card and get another.
Im not gonna sell it just because the ram sinks are attached together, thats insane.
Think i'll try the freezing method.
when you rip the RAM chips off of the PCB, please do post pictures! i could use a good laugh right about now.
maybe spending 300+ bucks on a shuttle and not doing your homework, then gonna ruin a 250 bucks worth of a video card is insane
im pretty sure the ramsinks wouldnt interfere with the audigy, and as for removing them, you are basicly SOL, since you will most likely rip off the ram chips right off with the sinks.
IceWind you are a pretty cool guy but I am gonna have to agree with the above quoted statement. :D
I don't know what the ramsinks look like, but could you cut the ends off, leaving the base on the RAM?
Try and use some tooth floss or a razor blade and gently use a back and forth method to cut between the BGA and the heatsink to seperate them.
