Will a few anti virus/spyware etc. pick these up and remove them?
Yes...just hit it with a shotgun approach. We deal with several per week. Quite a few threads each week about cleaning these.
And...there's a new twist on this..the latest variants hold your My Documents contents encrypted...for "ransom"..pay up 50 bucks and they'll remove the encryption for you. I have a thread started on it with links to the fixes for your Docs folder over in the Networking and Security forum.
Always had good luck with combo-fix and malware-bytes.
http://www.bleepingcomputer.com/combofix/how-to-use-combofix
http://malwarebytes.org/
Gotta tell 'em what it is... or can't you do that because of some NDA or whatever?
Does anybody ever even try the product I work on?
This posting is provided "AS IS" with no warranties, and confers no rights.
It's up a little ways...
Yes I've mentioned the MRT a few times....I've found it "sometimes" removes two or three things that the others seem to miss. As for running it the first time....as the only removal tool, sorry...I've not had much luck with that...it misses a lot. It just..seems to catch two or three leftovers that the others miss. So I tend to run it as one of the last scans....just in case it sometimes finds a couple of things the others missed. Usually though...it does't find anything if run after the others.
These rogues are releasing new variants 4, 5, 6...even more times per day. The MRT is only updated once a month if I'm correct? How is it supposed to keep up with the rogues?
I just cleaned up a laptop with some of that crap.
The laptop only had 256 meg o memory so it took a long time. I had to abort the original av scan cause it was taking too long. Here's what worked the best in the following order.
Download and update Malwarebytes and Avira Antivir.
Turn off system restore.
Reboot in safe mode.
Run malwarebytes, clean.
Run Antivir, clean.
Reboot
Download and update Superantispyware and scan. It found and cleaned up a few remnants the others missed.
Things looked pretty good after that. Turn system restore back on.
