cocheese256
- Apr 23, 2005
I have a new directv HD TIVO unit. Which means I have USB ports but they are not active. I may mod it some day so that I can activate the usb ports on it so that I can network it in with my home network and just send the movies over to my HTPC as files. However in order for me to do that I have to change drives in my TIVO, that means I can not get the movies that I have already recorded to my an HTPC. Also I dont really like the idea of modifing my TIVO. I noticed that there is an option on my TIVO that I can backup recorded data to a VCR. I would like to do this but not to my VCR but to my HTPC that is running MCE. In other words I would like to know if there is a way to record with my PC from my TIVO the same way you would with a VCR. I would also like to be able to keep my recordings in the same image quality. For example if it is a HD recorded channel, I would like to keep it in high def while it is being stored on my harddrive. I currently do not have my HTPC finnished so I could really use some suggestions on hardware, software, and the best way to do this. And if this works well enough I will not mod my TIVO.
