Best way to mount heatsinks?
thesmelliestsock.
What is the best way to mount your heatsinks on VGA RAM for best cooling performance?
The OCZ copper heatsinks come with thermal tape, but is there a better way?
That stuff is epoxy in disguise. Once you stick it in, it's not coming off without the ram chip. The best way is by applying four small dots of epoxy (or crazy glue) on the corners of the ramsink, and some AS5 in the middle.
