Hi. Ok, I finally got around to moving my rig from the right side of my computer desk to the left side. In doing so, the rig is now between my entertainment center and my computer desk, so I could hook up my computer to my 37" LCD HDTV.
Right now, I'm using DVI into the tv, and the "front out" from the soundblaster audigy gamer into the tv. This is an 1/8" stereo jack solution. I have two 19 inch monitors that I usually work with. My question is, using the supplied cables with my ASUS X1800XT card, can I hook up to the HDTV using the video out terminal on the card and the component video cables that plug into it, AND be able to use my two DVI ports for the two other computer monitors??
Is there a noticable difference hooknig a PC up via DVI as opposed to component?? I only haev two DVI cables right now. The one was being used to hook the digital cable box to the tv, and I had run the two RCA audio outs on the cable box to an 1/8' in for the tv. Right now the cable going into my tv tuner card is regular cable, its coming from a splitter. Should I run coax from the cable box into the computer? If so, I don't know how I would change the channels, other than using the cable box remote.
Please help an HTPC nOOb !!
Thanks
*edit* forgot to put my receiver specs. Pioneer VXS D811S. It's 6.1 (I'm only running 5.1 speakers), has Dolby Digital decoding and DTS. Don't know how to hook the Audigy Gamer up to it other than 2 speaker setup right now. I don't know "how" to make Soundblaster's proprietary "digital DIN" connection work on my receiver. Do I need some sort of adapter?
Thanks
