I've been using a laptop connection and a panel antenna with a USB adapter to access my Optimum wifi account while I'm at work. Problem is, is that the USB adapters seem to degrade over time to where they are no longer useable. I'm not that well versed on this stuff. Would I need a bridge or some other device? would something like this work? It says it can be configured as an adapter
http://www.newegg.com/Product/Product.aspx?Item=N82E16833156247
If not what would be a better solution? Thanks
