I have decided that I occasionally need to be able to access my home network.
(SMB server, RDP, etc). If I understand it correctly, I can put a VPN behind my router/NAT and I should be able to tunnel into the VPN and it will then appear that I am inside the network.
Is that correct? Does the VPN instead need to be part of the router/NAT?
