best way for second display?
stainremover
will this work for my purposes? should i spend more for a better quality adapter for better image quality?
yep that'll work fine. you need to spend the extra money on a "better" quality adapter. its a digital signal... it either works or doesn't.
that wont be quite true for long distances but that's not what were talking about right now.
go ahead and order that. also check out monoprice or dealextreme for that adapter. might be cheaper.
