Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Really vague, but I want everyones opion. What kit/setup will keep a Prescott processor as COOL AS POSSIBLE! Money=no option. b ut keep it to watercooling, no extreme stuff.
Forget the pump and reservoir. Get the block made out of gold or silver alloy. Hook it up to the garden hose from outside with a return line to the gutter (or the yard if you want to be enviromentally friendly ;-) Turn on the water, turn on computer, and enjoy! Well water is better if you have it as it is colder. If you want extreme performance run the H20 line through a radiator in the freezer before entering your computer. Just make sure not to let H20 freeze in the freezer!
Open loop watercooling is the f*cking bomb. That's my project here for the spring - free water on college campus Condensation is going to be a problem, but I can fix that easily enough.
