Well, I don't understand why people like kits so much
thanks such a noob here
Originally posted by enforcer17
well u missed out the rad for starters.
most people have it setup like this:
pump -> CPU -> other blocks -> rad -> res
i know most people have already seen it, but here is mine for a reference on a closed loop without a reservoir. I like it this way alot because it looks tidy and I don't have to change the water for months and months.
You're telling me the BIX2 is better than a caprice core? Have you seen the caprice core? They're about the same size. Performance should be able the same, at 1/3 the cost, and an extra fifteen minutes of modding. If you make $200 an hour, by all means, go for the BIX2
Well, kits in and of themselves aren't so evil... especially the dtek/dangerden kits. However, I royally dislike the BlackIce products. I feel they are a waste of money for what is basically a repainted car heater core, and they tend to come with kits. Hmmm, do I want to buy a bix2 extreme for $100+, or buy a caprice core and mod it for $25 (including parts/fuel/tax)
Well, I don't understand why people like kits so much. I did my very first water cooled computer without a kit.
I'd get a car's heater core, and cut off the barbs and solder on new ones. I did that to a 1986 chevette core, no issues.
Then go for whatever blocks you want (WW, z-chip, maze4 GPU or swifty equivalent)
Also, try out the Danner Mag3 or Eheim 1250. I've owned both and can vouch for them being excellent pumps. The Mag3 is slightly more powerful than the 1250, and cheaper/smaller too.
I use a T with a cap for my fill line. I used to have a Bay-res, but I wanted something that wouldn't let bubbles into my system when I moved it, and was tidier.
I also went the resless/t-less way like the above poster for a while, but it was a PITA to bleed.
Originally posted by kleptophobiac
You're telling me the BIX2 is better than a caprice core? Have you seen the caprice core? They're about the same size. Performance should be able the same, at 1/3 the cost, and an extra fifteen minutes of modding. If you make $200 an hour, by all means, go for the BIX2.
Originally posted by jpopa
how should i run things?
like
rez-> pump > cpu > chipset > rez ?
let me know, thanks kids
