Best waterblock for Exos?
MYST_2
I'm ordering an Exos from newegg this weekend and I'm wondering which waterblock would be best. I'm assuming it doesn't come with one. Also if it worth watercooling a video card. I'm running at the speeds in the sig right now. How much mroe could i get out of her.
the EXOS uses 1/4 hoses, so ur limited to that size.
the Koolance works fine for me,CPU-200g
they did come out with a new line of cpu coolers, (300 series), and the only diff i see is that you can fit bigger size hoses on there.
but the EXOS is limited to the 1/4" , so just go with the 200g, unless ur planning on making or custom ordering your own block
yes the 200g is compatable with AMD and P4
-paulm
you can get a maze 3 or 4 from dangerden you just have to ask them to put 1/4 barbs on or order them separtly
go for the new koolance coolers ..they look nice and preform well from what i hear
200G all the way. Had a Maze 3 on Exos for a little while, the performance was a little worse with it then the 200G.
