Ok im now building a loop for cooling just my processor. ITs a Core i7 920 currently at 3.6ghz hoping for more. Right now i cant increase vcore beyond 1.285 because my temps are out of control. Im looking at the EK blocks, Swiftech, Danger Den, etc. What block is best? i cant find a comparasion. Im thinking either a swiftech dual 120 or triple 120 raiditor for this setup. Also what pump would you reccomend. I have a 655 driving my GPU system now and its working well. The guy at crazy pc told me to just splice another raiditor and the cpu block in line and that the 655 can handle it? IF so great it saves me the purchase of another pump. IF not then what pump would you recommend for the cpu only loop. I plan to run the skythe 110cfm 120mm fans. I know a bit loud but i can live with it.
How much better realistically can i expect my temps to be?
