Best Water Cooling Kit?
nikoq
Hi all,
Because I am tired of all that noise coming out of my pc, I decided to go for a water cooling solution.
Of course because I don’t know much about it I will get a water cooling kit, here I need your help.
Which you think is the best water cooling kit on the market right now?
Thank you.
If you must have a kit I would suggest the new swiftec kits with the 6000 series cpu block. Other than the slight loss in performance from the 3/8 ID tube and radiators that could be better it is an excelent kit specially for under $200.
Check out the Asetek Waterchill with the Antarctica block too. Looks pretty good, especially for a first timer to water cooling.
