basically, im trying to figure out if i should keep my 7900gt + buy stock cooler
or, if theres a different card i should buy, one that'll be queit in a single slot cooling solution (passive?)
There's an XFX 7950GT that's passive and "single-slot". I say "single-slot" because the passive cooler part takes up the slot above it and not below it. Most motherboards situate the PCI-E 16X slot as the top slot (generally) so you shouldn't lose much expansion. However, I don't its worth dumping your current card for one that will be only slightly better. I think you're better off waiting for a single slot 8600.
