Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
$300 canadian?
I guess a little over wont hurt, preferably an ATI, which would be the best bang for my buck.
Im looking at the ATI 9800 Pro's, but is there much difference between a 9500 Pro, Or a 9700 pro? IS it worth the extra money, help?
If you insist on ATI, how much is a x700 pro XT or otherwise in canadian money? I don't think I would buy a x600 but the x700 is fine and fast and cheaper than the 9800's and better...
But if you were smart, I think you should look at the @220 or less 6600Gt's as well.
If the poster is looking at purchasing a 9500/9800 card than he probably doesn't have a PCI-E port on his Mobo, so an X700XT/6600GT is out of the question.
For $350 CAD you can get a 9800pro (you might be able to get it for as little as 250 if you catch it on a sale). The 9800pro is about 40-50% faster than a 9500pro and would be a way better choice.
At this point, the 9800pro is the best choice for mainstream buyers in the AGP market (at least until 9800XTs come down in price).
