best video card for my machine, help
kethwika
upgrading to a fx 55 and a asus A8N-Sli premium and im gonna be running linux on this system so i think a geforce card might be best but i dont know just want a good card that is supported under the mobo im getting. any recommendations ati or geforce what do you think. im runnin a 9800 pro 256 and i want something to kill that
thanks guys
Well, it depends on if you want to game and what price range you are looking at.
Answer these questions and I can give you a couple of good suggestions.
Zero
Here a choices u can pick (list from the highest to lowest):
(SLI)
7800GTX**
7800GT***
6800GT
6600GT*
(Single)
7800GTX**
X850XTPE***
X850XT**
7800GT**
X800XTPE
X800XT
6800GT*
X800XL*
6600GT*
* for budget card with FX-55 and possible less bottlenecked
** for insane gamin @ high quality with FX-55
*** for my suggestion with good gaming result
Hope this help lol.
If you only play cs a 6800GT would do you fine and it'll kill that 9800pro just fine. OCing could make it an ultra as well. But why? lol
Plus it's an nv card for driver support.
~Adam
i would say nvidia b/c they support pixel shader 3.0 and can do SLI.
also the 7800GT will be out Aug 11 so you might as well wait for prices to drop.
if you dont want to play 399 for that card get a 6800.
You're running Linux. It's nVidia all the way. The real question becomes a matter of how much money you're gonna spend.
