Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
as in programs to use to benchmark your system while playing a game? if so then use fraps, if you are talking about actual benchmark software like heaven or 3dmark11, they are all free.
ahh well you can still run the heaven benchmark but in dx10 without the tesselation i believe, otherwise you are stuck with cinbench11.5 openGL, 3dmark vantage and older versions. theres a few other ones out there as well though.
