Best vide capture device?
lingding
I really need some feedback on what you guys think is the best video capture device out there so far? I'm going to be doing a lot of video editing on my computer. I've been Newegg for a while now but I can't decide (I don't know what would be best for me). I would prefer to have front access to the red,yellow,white connectors so I can plug in my VCR or anything else. I'm also looking for one which has the 1394 4-pin for my digital camcorder. These preferences aren't a must. There are also total separate boxes which are external.
Right now the best one I've seen so far is on Newegg here http://www.newegg.com/Product/Product.asp?item=N82E16815123101
however I'm worried if the quality will be just good or great. If you guys know ANYTHING that might help please respond.
Check out the ADS products. I've been using the InstantDVD for quite a while and
it's really good. It's a hardware encoder, and does a good job. Price is decen too, as long
as you don't buy it directly from the company :)
-Jeff
