best vid upgrade path for me
unix8814
Right now I have a
-p4 northwood 2.4ghz 533fsb @ 2.5ghz
-1gb ddr400 dual channel
-intel 875 board 8x agp :( only lets me overclcok 4% casue its made by intel
-radeon 9500 128bit mem unlcoked to 8 pipes
-antec 2650bqe w/antec 480 trueblue
-120gb wd special edition
Options
A- Just leave it be
B- New vid card (looking for your opinion)
C- This machine isn't worthy to process another polygon
It's entirely up to what you need to get out of this system, and what kind of games you play/anticipate playing.
If you're looking for something to tide you over for about another year or so, something until the next big system build, I'd say work on overclocking the processor you've got, and grab this 6800GS. Unlock the pipes and vertex shader, overclock it a little, and you've got yourself a 6800GT. That setup should last you for a fair amount longer, and let you play games like COD2 and Fear with decent settings.
If you're looking to make this upgrade last you longer than about a year and you plan on playing the latest games on high settings, then its time to sell off that system and build a new one. If this is the case, I'd wait until summertime comes around and socket AM2 arrives before you make your decisions on parts.
bLaCktIGErs91 said:
Give us a budget for Option B
:p
Exactly. Those specs aren't horrible, it just depends on what kind of money he is working with. Obviously, the video card is the thing that needs replacement the most.
build a new rig
a64 venice @ 2.7 = 90 bucks
DFI ultra = 85 bucks
BH5 1gb @ 222? = 100 bucks
6800gs or 7800gt = 150 - 210 bucks
425 - 485 depending
play your cards right and i will only cost you like $250-$300 to upgrade to a smokin fast system
cheers,
mal
that 6800gs would be good but I would get a X850 class videocard if you could find one in your price range
I recently got 2 x850 pro's on ebay (one for me and one for my bro) for 175$ and 190$ Most of the ones there you can unlock the extra pipelines (only 1 of the 2 i was able to unlock the pipes although they looked exactly the same.) but if your looking for a good card i would get a x850 or a 6800 :)
Well, the X850XTs are pretty good... but unfortunately I think they might have stopped making the AGP variants...
