SpiderWaffle
- Jul 4, 2007
I was thinking the ZALMAN VF700-CU was one of the best options. It only cost about $30 or $15 from e-bay.
Is there something else that gives better cooling for cheap?
I wish they made like a normal CPU cooler that mounted on a VGA. I've got plenty of room below the card, I think most people do too.
For my last video card I drilled holes in my AMD stock HSF and bolted it on. It kept my GPU 2 degrees above ambient, compared to 33 from the stock cooler.
