- Dec 28, 2006
Looking to add a USB 3.0 pcie-x card to run my front USBs. Just wondering which chipset is the fastest and most reliable. Seems like the most common are Reneasa, Via, and NEC. I'm am only going to run 2 front ports and I will be looking for a powered card just for the peace of mind that I will be able to power whatever I plug into it. Linkage with your suggestions is always good
Pre-thanks!
