Best Thermal Tape?
//[T.0.P]//
I was just wondering what was the best thermal tape you could buy. I know Artic Silver is supposed to be really good, but they don't make thermal pads. My Accelero X1 from Artic Cooling came with some pads and isn't Artic Cooling a pretty good thermal paste goin company?
Any comments would be appreciated!
I see in that thread that you mentioned buffing the surface of the ram chip with grit paper. Have you tried the Artic Silver Surface Remove and Purifier? I've been using that when I've been working on new processors and stuff and it seems to do the job quite nicely. I even used it to remove the gunk off the the ramchips on my previous 7900GTX when I tried the Accelero X1.
