BUt I DO NOT WANT TO SPEND 10$ A BOTTLE! Anybody know where they sell em that big?
Tareon said:I've got AS5, but for some reason when I used it, compared to the thermal paste that came with my stock and Tt HSF, it ran about 8-10 degrees hotter.![]()
Tareon said:AS5 isn't (theoretically) electrically conductive, is it? Hmm, with the amount you spread onto the core anyways, it shouldn't touch the bridges at all.
thelarry said:Artic Silver epoxy cut 1:1 with Artic Silver so you can remove it later using the "freezer trick". It works well and is a lot better than thermal tape.
