Best Temp/Fan/Power monitor Ryzen 2600?
rudedog89
Currently, I am using the CAM NZXT software, and even though its ok, I would like something a little more configurable.
On my old system, I was using Open Hardware. I loved it. The widget was configurable is why. Unfortunately it has not been updated for Ryzen, etc.
Does anyone have a good monitor software like Open Hardware with a customization widget?
I have tried searching and all the suggestions I have read are . HWInfo, CAM, CPU Temp. None of them have a configurable dashboard or widget.
Thanks in advance for you help.
FearTheCow
I am using a corsair commander pro, gets the job done and is pretty easy to use. The only thing I don't like is the way it logs data really only gives a min/max.
rudedog89
Fear, I don't know if I want to pay $70 for something, but, if it works, I might look into it.
Question, do you have to use that module to use the software?
FearTheCow
Yup, you are locked into using the commander, just saw you want to use a widget, the only options for corsair icue software is having the program dashboard window open or the built in windows "pop up" screen.
I have 6 fans, corsair led strips, and a water temp sensor connected to my commander pro. I am really hoping they update the software to have better logging sooner or later, only being able to have a general idea of temps in the graphs kind of sucks, though I am mostly interested in idle and max temps myself.
What exactly are you looking for? I am happy to give yes/no/more detailed answers on what icue/corsair commander can and cannot do.
rudedog89
Have you looked at HWMonitor Pro?
Ded,
I did look into that one as well, but, didn't notice any widgets with it.
What I have been using and seems to work fine is, HWInfo64 with the windows gagdets . Seems to be working for me.
Thanks for the suggestion
