I wouldn't spend too much on a tablet just to play games. Your best bet is Galaxy Note Pro 8.4 for about $200.
I'm looking for a tablet and I'm a bit lost.
I need:
1.) >/= 1920x1080
2.) Graphically powerful (for games)
3.) >9"
4.) It has to be black.
Thanks!
Agreed, you really don't need much in the way of hardware to play tablet oriented games on any of the major platforms. Windows devices and the wrinkle of being able to play some desktop games locally. There are a good number of older games that run pretty well even on cheap Windows tablets at the lowest settings, however modern Windows desktop games will struggle on even the most powerful Windows tablets as they all use Intel IGPs. Except the Razor tablet I believe if that's still available.
What's your budget?
I'd steer clear of Samsung for now, since the Galaxy Tab Pro is old, and the Tab S is slower than that -- maybe there'll be refreshes in February.
One thing to remember: it's still true that iOS tends to get more of the nicer tablet-native games first. The gap isn't always huge, but it's there. It took several weeks after the iOS release for Monument Valley to hit Android, for example. You'll also occasionally run into quality iOS exclusives like Revolution 60 or Vainglory.My main concern is just what you mean by gaming. You'd want something like an iPad Air 2 or Nexus 9 if you want something that's great for the latest 3D games, but basic 2D stuff can easily be handled by cheaper hardware.
Do I have to choose? I mean, can't I just get an Android tablet and install Windows 8 on it? I thought Windows 8 supported any ARM CPU.
Windows 8 on ARM really isn't user installable. However if you were to go with a more powerful x86 Windows device like the Yoga, you can install any number of Android emulators that on good hardware will give you very good performance overall. If you want it all on one device then something like a Windows 8.1 Core M device or better and an Android emulator.
Galaxy Note Pro might be old in the Android world but it's equivalent to the new iPad Air 2 in specs with 2GB DRAM and real world game and app performance (ignore misleading benchmarks) so it's better to spend $200 vs $500. For $500 I'd start looking at laptops with discrete graphics that run PC level games and not toy apps.
I can't comment on games with the Galaxy Tab Pro 8.4, but movie playback has been a disappointment, IMO. Playback on Netflix and movies on local storage has been choppy. Colors are washed out, too. I'm probably going to return mine.![]()
Maybe I got a dud? For $200, it's quite a deal. I like the size and thin form. My main use is media consumption, so video/TV performance is important to me.I don't bother with netflix, but local storage video playback is one area it hasn't disappointed. Colors are solid and realistic as well. on mine.
Tab Pro 8.4 is already hitting 60 fps limit @ 2560x1600 on a real game engine Epic Citadel. If you think iPad Air 2 can do better post a video. Until then it still stands that Tab Pro 8.4 is the best bang for the buck.
http://youtu.be/alrEbq62U0A
I tried fiddling with an Androind emulator years ago.. didn't work out too well. I'll give it another go, I suppose. Nice to see they can work without ARM.
In regards to Yoga - isn't Core M a huge disappointment? I was actually thinking of just getting a good deal on a Yoga 2, instead of the Yoga 3 Pro. I also don't see the point of 4k on a 13" screen.. especially with games. Even old games will require massive amounts of vRAM.
Nvidia shield tablet. Hands down. Stream pc games, grid game service, android and amazon apps galore a kick ass stylus and game controller to really round out the experience. For gaming the air 2 and galaxy pro can't toutouch it at all.
Epic Citadel also doesn't have characters, gameplay or any significant physics tests running, and its last update was in 2013. It's as much a "real" modern game test as trying a two-year-old version of 3DMark on your PC -- I've seen reports of Citadel nearing 60FPS on a Nexus 4, for goodness' sake. My original iPad Air doesn't break a sweat.
The Tab Pro 10.1 (not 8.4, the OP ruled out tablets under 9 inches) would do well for a lot of gaming, but there would still be a difference for particularly intensive titles. It depends on whether he wants to buy a tablet that's good for what's out now, or whether he's willing to pay extra for something that's more futureproof.
You need to nail down what you want the device to do. There are three viable tablet OSes, iOS, Android and Windows. Each has its strengths and weaknesses. iOS with iPads are the best overall, no hassle, well supported software ecosystem. Android give the most hardware and software variety with touch only. Windows devices are the most complex and flexible overall with the least amount of touch only software.
Apple must have really done a good job on the A8, considering it's a triple-core processor that beats octo-core processors on Android devices.
I never meant to insult, I was simply trying to provide a non-controversial and concise synopsis of the three major tablet OSes. Apparently I failed to do so in this case.
That said, Windows 8 on tablets is no problem for a lot of people. Using the desktop might present a challenge but it's also the reason why some like Windows on a tablet. Not even Android is as flexible as the Windows desktop on tablet. Windows 8 is complex on tablet, but not hard to figure out.
I'm confused now to your requests. You want a tablet for gaming but now you just want a tablet. You bounce back and forth between android and iOS but them talk about installing PC games. If you want PC games them you need a windows tablet running windows 8. The surface pro lines or the Yoga would best be suited for those. The shield tablet can play PC games off the Grid service or stream them from your home PC. Also the shield hub store has a lot of great PC games half life 2, portal, oddworld, as well as a lot of bioware RPGs.
The air 2 and galaxy tablets can play a lot of those games but would be unable to stream from your PC or use the Grid service for ota streaming. I don't find the shield tablet bulky or heavy at all but of course it is under your 9" requisite but it is hands down the best tablet overall. It is just under the air 2 in power but has a better screen, more flexibility due to being almost a pure android experience, and has more gaming features. The stylus is better than any of my previous tablets and excels in note taking and sketching when bored.
I currently own a galaxy pro s, surface pro 2 & 3, wife has an air 2, and I've got a couple hdx kindles, Venue 8 pro, and a nexus 7 and hands down I'd recommend the shield tablet over all of them. If you still feel the same about it then the air2 would be next unless you can spring the cash for a surface pro then I'd grab one of them.
Actually hoping, with the announcement of Tegra X1, that a new Shield device will make another good improvement here (like the Shield Tablet made over the original Tegra Note).
It also isn't so much that Apple necessarily did a "good job" but also that their design philosophy differed. Although in terms of smartphone workloads I think you can argue that their stance makes more sense, less but faster cores versus more but slower cores. When even desktop workloads and application still struggle to fully leverage 4 cores you can probably imagine how well 4 cores are actually leveraged on smartphones.
To be honest, I'm still not seeing the appeal of the Shield.
On the one hand, you've got PC games to play on it but how many of those work well on a touchscreen? Not to mention that even a Tegra K1 is around as powerful as an Intel HD 5300 (if memory serves me).
On the other hand, you've got Android games to play, but if Tegra K1 is only available in the Shield and most games are rendered to meet the lowest common denominator, I don't see how the experience can be better than any other tablet.
Actually, it sounds exactly like Apple did a good job.
The idea to have three powerful cores instead of four or eight less powerful cores is a very wise one, indeed.
I remember the only debates of Dual-Core vs. Quad-Core where the obvious answer eventually became Dual-Core because the E5000 series was overclockable to 4.5Ghz+ on air and the Quad-Core CPUs could barely reach 3.2Ghz.
This was a long time ago and on the PC where multiple threads can be far more easily utilized. So, why Android manufacturers have decided to up the cores instead of relying on more powerful but less plentiful cores is beyond me..
Seems like something Apple would do, actually. Increase their CPUs to eight cores and claim that it's the most powerful.
So, in the end, Apple has the most powerful mobile hardware? In which case, their price premium is technically worth it? Damn.
Couple small corrections:
There's actually a decent amount of touch software in the store as quite a bit of it works on win phone or win on a tablet.
If you want to invest the time in getting it up and running, BlueStacks is supposed to work great in running quite a bit of Android software on windows.
I'll say this, shield tablet is definitely a gaming tablet. pc game streaming works well both at home and away. grid is awesome and continues to get better as it approaches full launch. supports USB devices through OTG and charging, and with a connected or bluetooth mouse/keyboard, you can play desktop games and throw them on a big screen through hdmi. also the screen may not be the best but it was plenty bright enough to read ebooks on while i was on vacation at a beach. Also nvidia pumps out updates nearly as fast or faster than google sometimes, compared to other tablets that may get one update or none at all. All great things aside it feels like a developer tablet, so as long as your ok with some quirks here and there, none of them show stopping, its a solid tech person tablet.Nvidia shield tablet. Hands down. Stream pc games, grid game service, android and amazon apps galore a kick ass stylus and game controller to really round out the experience. For gaming the air 2 and galaxy pro can't toutouch it at all.
I must have caught Netflix on a bad day or maybe my internet connection was weak. After several more viewings, my Tab Pro 8.4 has performed really well on Netflix. I've not tried any movies on SD card, yet. I'm less inclined to return the tablet, now, especially since my main use will be reading books, newspapers, FlipBoard, Pulse, etc. I had a Nexus 7 2013 which was replaced by this Tab.Sorry you're experiencing that with your Tab Pro 8.4, I recently got the $200 bestbuy tab pro 8.4 and currently own a 2013 Nexus 7, the Tab Pro has a better screen and netflix has no issues with streaming. I still prefer the Nexus 7's battery life, but I guess that's the price you pay for more screen and brighter. The speakers on my Tab Pro 8.4 also sound better than the 2013 Nexus 7.
