mwin
- Jun 24, 2004
I had a 7800GTX. It died. I can get a new one for $250. Is this my best buy for less than $300?
Joebar said:Forget about the 7900 GTOs... They're out of stock, will probably not be back in stock..
Garric said:I think for your price range it would be imperative to get the 8800 GTX (~500$) but it's low in stock so you gotta be patient.
Mark305TBI said:Alright, I see three cards here that fit my budget...so let's narrow it down:
(ranked in order of consideration)
1. BFG Tech GeForce 7950GT $269.99
2. ASUS Radeon X1900XT $269.99
3. ATI X1950 Pro ~$200
I use the computer that the card will reside in on a 1280x1024 LCD. Usually just FPSes (I'm still hooked on FEARs multiplayer...). Whichever one I get will have my maze4 slapped on it, so the effectiveness/noise of the stock coolers aren't a concern. So, if you were me, which one would it be?
Does it, really? I did find it on NewEgg, and you're right about the price.Foolfighter said:I'm confused
The 1950XT owns all the cards you mention - its about $270
